Plesk for Windows
kb: technical
ABT: Group B
- Plesk for Windows
Warning when connecting to the domain via FTPS:
CONFIG_TEXT: example.com:21 - Hostname does not match certificate
The same certificate is used for securing Plesk panel.
Default Plesk certificate is used for FTPS connections to the domain.
Ignore the warning. The connections are secured by Plesk panel certificate.
There is no possibility to install SSL certificate for a particular FTP domain. Refer to this article for details.
