It is not possible to move messages between mail folders using any mail clients when the IMAP connection is established to the mailbox hosted in Plesk.
The following error can be found in the
/var/log/maillog
file:CONFIG_TEXT: dovecot: service=imap, user=johndoe@example.com, ip=[::1]. Error: Mailbox INBOX.Spam: file_dotlock_create(/var/qmail/mailnames/example.com/one/Maildir/.Spam/dovecot-uidlist) failed: Permission denied (euid=30(popuser) egid=30(popuser) missing +w perm: /var/qmail/mailnames/example.com/one/Maildir/.Spam, we're not in group 0(root), dir owned by 0:0 mode=0775)
CONFIG_TEXT: dovecot: service=imap, user=johndoe@example.com, ip=[::1]. Error: stat(/var/qmail/mailnames/exampl
e.com/one/Maildir/.Spam/tmp) failed: Permission denied (euid=30(popuser) egid=30(popuser) missing +x perm: /var/qmail/mailnames/example.com/one/Maildir/.Spam, dir owner missing perms) -
The domain backup with the selected Mail configuration and content option in Domains > example.com > Backup Manager > Backup, fails with the error:
CONFIG_TEXT: WARNING: (Mail object 'example.com') Not all the data from /var/qmail/mailnames/example.com was backed up successfully:
/Maildir/one/cur: Cannot open: Permission denied
Incorrect permissions for the mail folders in /var/qmail/mailnames/
directory.
Log into the server via SSH.
Run the command below to set correct permissions for the mail folders in
directory:# find /var/qmail/mailnames/* ! -user popuser | grep -v .spamtrain | xargs chown popuser:popuser
