A website does not work: DNS_PROBE_FINISHED_NXDOMAIN when DigitalOcean is used
3 comments
    R Roeleveld
    Unfortunately this patch did not solve the issues with the DO extension not updating. My complete and most busy zone is down and I can't get Plesk support because I bought my license through a reseller..?
    Maxim Krasikov
    Hello @R Roeleveld !
    Probably, you faced another bug #EXTPLESK-894.
    Please try applying the hotfix provided in the article:
    https://support.plesk.com/hc/en-us/articles/360022927274
    If the solution is not helpful, contact your hosting provider for the assistance.
    R Roeleveld
    Thank you for providing me with that article. So far it seems to have solved the issue, I need to do some more testing to be 100% positive.
    The thing with the support is, I am my own webhoster and purchased my license through a Plesk reseller. I wasn't aware that buying from a reseller excludes you from contacting Plesk directly. Fortunately my license is soon up for renewal and I think I'll buy my future licenses from Plesk directly instead of the reseller.
    Again, thanks for helping me with this.
