After March 20, 2019, installation of system updates on Plesk servers with Debian 8 fails: Failed to fetch http://ftp.debian.org/debian/dists/jessie-updates: 404 Not Found
13 comments
    Simone Fagoni (Edited )
    For ovh users:
    /etc/apt/sources.list
    # jessie-updates, previously known as 'volatile'
    deb http://debian.mirrors.ovh.net/debian jessie-updates main
    deb-src http://debian.mirrors.ovh.net/debian jessie-updates main
    to
    #deb http://debian.mirrors.ovh.net/debian jessie-updates main
    #deb-src http://debian.mirrors.ovh.net/debian jessie-updates main
    2
    visualnetwork
    Hi!
    I have the same problem, but my /etc/apt/sources.list file is:
    deb http://mirror.unitedcolo.de/debian/ jessie main
    deb-src http://mirror.unitedcolo.de/debian/ jessie main
    deb http://security.debian.org/ jessie/updates main
    deb-src http://security.debian.org/ jessie/updates main
    #deb http://mirror.unitedcolo.de/debian/ jessie-updates main
    #deb-src http://mirror.unitedcolo.de/debian/ jessie-updates main
    deb http://updates.atomicorp.com/channels/tortix-common/debian jessie main
    What should i rewrite for what?
    Thanks,
    Laci
    1
    Artyom Baranov
    @Andrea Candian,
    Hi! You are right. That is because Debian 7 (Wheezy) has reached its end-of-life in 2018 and is supported neither by its developers nor by Plesk support.
    Konstantin Annikov
    @Stefan Schulz
    You are right. In case backports repository is in use, links to it should be changed from debian.org to archive.debian.org.
    However please note that packages from backport repository were not tested with Plesk and they could cause unpredictable errors.
    Stefan Schulz
    Thanks. I don't think I need it. So hash it will be.
    Cheers,
    Stefan
    Andrea Candian
    Same issue with wheezy.
    Stefan Schulz
    @Konstantin Annikov
    Using archive I already tried, but it does not work:
    E: Release file for http://archive.debian.org/debian/dists/jessie-backports/InRelease is expired (invalid since 40d 21h 52min 38s). Updates for this repository will not be applied.
    Thanks,
    Stefan
    Stefan Schulz
    This solution only works half way, as there is a second failure popping up:
    ''Failed to fetch http://ftp.debian.org/debian/dists/jessie-backports/main/binary-amd64/Packages 404 Not Found''
    Is it recommended to comment out the corresponding line as well?
    Cheers,
    Stefan
    Ivan Kamnev
    Hello @visualnetwork,
    As I can see the required repositories are commended.
    Please create a ticket to Plesk support using the link below that we can check this situation:
    Lenor
    also other Lines?
    "deb http://security.debian.org/ jessie/updates main contrib non-free" ?
    Konstantin Annikov
    @Stefan Schulz
    I should warn you that it is the Debian's FTP masters team decided to remove the jessie-updates and jessie-backports suite from the mirrors. This was announced on debian-devel-announce, resulting in the errors quoted in article.
    That is why, the error you are reporting says that repository is out of sync with the main Debian host for a long time.
    With the APT version in jessie, this cannot be ignored on a per source basis. So you need to disable this check globally, using this command:
    \# echo 'Acquire::Check-Valid-Until no;' > /etc/apt/apt.conf.d/99no-check-valid-until
    However this should be done only in case you are sure that you need this repository.If you are not sure, you can also just disable this repository by inserting '#' symbol at the beginning of the string with this repository.
    Konstantin Annikov
    @Simone Fagoni
    Yes, your modifications are correct.
    Nikita Nikushkin
    Hello @Lenor,
    No, it is not required to disable this repository:
    because it still exists and works:
    http://security-cdn.debian.org/dists/jessie/updates/
    Please also note that the affected repositories are "jessie-updates" only while "jessie" and "jessie/updates" still works fine
