Plesk for Linux
kb: technical
ABT: Group B
Additional License for Advanced ModSecurity Rules by Atomicorp is installed:
Advanced ModSecurity Rules by Atomicorp is successfully enabled, however the following fields are empty:
No errors can be found in the
/var/log/plesk/panel.log
file even with enabled debug logging enabled.
- Advanced ModSecurity Rules additional key is corrupted
- Additional license key is not synced with main Plesk license key
Go to Plesk > Tools & Settings > License Management and click on Retrieve keys;
- If the issue still occurs, select another rule set, e.g. OWASP ModSecurity in Tools & Settings > Web Application Firewall (ModSecurity);
Remove key for Advanced ModSecurity Rules by Atomicorp:
- Retrieve keys as described in Step 2;
Enable Advanced ModSecurity Rules by Atomicorp back in Tools & Settings > Web Application Firewall (ModSecurity).
