[FIXED BUG] Plesk does not show warning for piped logs on x64 systems
2 comments
    Faris Raouf
    I am not clear on this.
    Does it mean that on x64 systems, piped logs are *not required at all* when hosting more than 300 domains?
    If not, what is the suggested solution when hosting more than 300 domains?
    Ivan Postnikov
    Hello @Faris,
    You get it right, on x64 systems piped logs are not required.
    The suggested solution is to leave this part of the configuration in a default state.
