Unable to hide button "Tools & Settings > PHP Settings" in Plesk's Power User view with custom view enabled
3 comments
    Hosting Team
    Hello,
    The suggested CSS did not work for me on the latest version of Onyx.
    I had to change it to the following:
    [data-identity="buttonPhpSettings"] {
    display: none !important;
    Taras Ermoshin (Edited )
    Hello @Hosting Team!
    I have double-checked the solution provided in the article on two test servers: one with Plesk Onyx 17.8.11 Update #64 and another one with Plesk Obsidian RC3 18.0.17. On both servers, the solution from the article works correctly while the one shared by you doesn't work.
    If any further assistance is required on this topic, consider submitting a request to the Technical Support department.
    Hosting Team
    Thank you for double checking. It is odd that the results are not the same as we're also using Version 17.8.11 Update #64.
    In either case, we'll continue eagerly awaiting Obsidian and other future updates for an official fix.
