Plesk for Linux
kb: bug
Plesk repair installation launched from Tools & Settings > Diagnose & Repair failed:
PLESK_ERROR: {"id":1,"cmd":"plesk repair installation -y","type":"failed","message":"Reconfiguring the Plesk installation","level":0,"details":"Another instance of bootstrapper is already running. Please\nwait until it finishes.\nIf you are completely sure there is no other instance running,\njust remove \/var\/lock\/parallels-panel-bootstrapper-running.lock\nfile and retry.\nNote: running more than one instance at once may badly damage\nyour system.\n"}
This is a bug with ID EXTPLESK-2336 which will be fixed in future updates.
Connect to the server via SSH
Launch the repair utility via command-line:
# plesk repair installation
