Plesk for Linux
kb: how-to
ext: composer
How to disable auto-updates for Plesk Composer extension?
Connect to the server via SSH
Edit the file /usr/local/psa/admin/conf/panel.ini ad add the following lines:
[ext-composer]
enableSelfUpdates = falseNote: It is also possible to edit
panel.ini
file using Panel.ini Editor extension
