- Plesk for Windows
How to restore Plesk system databases from a Plesk daily/pre-upgrade dump?
If some of system databases got corrupted, but there are no manually created backups available, use Plesk daily/pre-upgrade dumps for restoration. To learn more about Plesk daily/pre-upgrade dumps, see the Additional Information section.
To back up/restore these databases, connect to a Plesk server via SSH (Linux) / RDP (Windows Server) and follow the instructions below:
Restoring from a Plesk daily dump
Switch to the directory with daily dumps:
# cd /var/lib/psa/dumps
List all available Plesk daily dumps:
# ls -l mysql.daily*
-rw------- 1 root root 236253 Feb 3 01:51 mysql.daily.dump.0.gz
-rw------- 1 root root 229653 Feb 2 01:48 mysql.daily.dump.1.gz
-rw------- 1 root root 222485 Feb 1 01:56 mysql.daily.dump.2.gzwhere
is the most recent daily dump.Example 1: Restoring a single system database
The following command restores the Plesk 'psa' database from the latest available daily dumpmysql.daily.dump.0.gz
:Note: To restore another system database, replace psa with a database name you want to restore.
# zcat mysql.daily.dump.0.gz | sed -n '/-- Current Database: `psa`/,/-- Current Database:*/p' | plesk db
Example 2: Restoring a single table
The following command restores the Plesklog_actions
table from the latest available daily dumpmysql.daily.dump.0.gz
:# zcat mysql.daily.dump.0.gz | sed -n '/-- Table structure for table `log_actions`/,/-- Table*/p' | plesk db
Example 3: Restoring all system databases
The following command restores all system databases from the latest available daily dumpmysql.daily.dump.0.gz
:# zcat mysql.daily.dump.0.gz | plesk db
Restoring from a Plesk pre-upgrade dump
Pre-upgrade dumps are used to restore the system to previous state if Plesk/MySQL upgrade has failed.
Switch to the directory with pre-upgrade dumps:
List all available pre-upgrade dumps:
# ls -l mysql.preupgrade*
-rw------- 1 root root 212341 Feb 1 05:18 mysql.preupgrade.12.5.30-12.5.30.20190214-051821.dump.gz
-rw------- 1 root root 213230 Feb 1 13:50 mysql.preupgrade.12.5.30-17.8.11.20190214-135000.dump.gzIn the example below, we are restoring all system databases from a dump file that was created before an upgrade from Plesk 12.5 to Plesk Onyx 17.8.
Restore system databases:
# zcat mysql.preupgrade.17.8.11-17.8.11.20180902-224319.dump.gz | MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -uadmin
C:\> cd %plesk_dir%Mysql\Backup
List all available Plesk daily dumps sorted by date (newest first):
C:\> dir /O:-D
Directory of C:\Program Files (x86)\Plesk\MySQL\Backup
10/18/2018 02:07 AM 106,128 horde-20181018020721.sql
10/18/2018 02:07 AM 122,124 config-20181018020721.reg
10/18/2018 02:07 AM 28,707 apsc-20181018020721.sql
10/18/2018 02:07 AM 389,032 psa-20181018020721.sql -
Restore a system database:
The following command restores the Plesk psa database from the latest available daily dump
:C:\> plesk db < psa-20181018020721.sql
To learn more about Plesk daily/pre-upgrade dumps, click on the section below:
For security reasons, Plesk automatically creates dump files that include system databases.
Linux
On Linux servers, Plesk creates two types of dump files - Plesk daily dump and Plesk pre-upgrade dump.
By default, these dump files are located in /var/lib/psa/dumps/
(The directory is defined by the DUMP_D
variable in the file /etc/psa/psa.conf
). To list these database dumps, run the command:
# ls -l /var/lib/psa/dumps/mysql*
Plesk daily dumps
Every night Plesk automatically creates a daily dump of system databases in scope of the Plesk daily task
/etc/cron.daily/50plesk-daily
.A daily dump file has the name
mysql.daily.dump.X.gz
, where X is a number starting from 0 (0 means latest). The following databases are included in it (in order of appearance):- psa
- mysql
- horde
- sitebuilder5
- apsc
- roundcubemail
- phpmyadmin_*
Plesk pre-upgrade dumps
Before upgrading Plesk or installing important MySQL updates, Plesk Installer creates a pre-upgrade dump of system databases. Pre-upgrade dumps are used to restore the system to previous state if Plesk upgrade/update has failed.
This dump file has the name
mysql.preupgrade.PLESK_VER_BEFORE-PLESK_VER_AFTER.DATE_CREATED.dump.gz
. The following databases are included in it (in order of appearance):- mysql - MySQL system database
- psa - Plesk system database
- apsc - Plesk application database
- horde - Horde database, if installed
Windows Server
On Windows servers, every night Plesk automatically creates a daily dump of system databases in scope of the scheduled task Backup of vital Plesk settings in Windows Task Scheduler (command C:\Program Files (x86)\Plesk\admin\bin\sshost.exe --settings-backup
These dump files are located in %plesk_dir%Mysql\Backup
. The following Plesk databases are backed up:
3 comments
looking for the dump created by the repair tool
My server is running out of space. Is there a way to prevent daily dumps? Maybe limit the number of dumps to just 1?
I was thinking in commenting the line "/usr/local/psa/bin/mysqldump.sh >/dev/null 2>&1" of /etc/cron.daily/50plesk-daily, is this safe and enough for prevent them?
#!/bin/sh
### Copyright 1999-2017. Plesk International GmbH. All rights reserved.
# install_statistics
/usr/local/psa/bin/sw-engine-pleskrun /usr/local/psa/admin/plib/DailyMaintainance/script.php >/dev/null 2>&1
# install_mysqldump
Thank you
Hi Ricardo E
We do not recommend to modify the mysqldump.sh script as the changes might be overwritten by Plesk updates.
The best way would be to allocate more disk space to the server.
You can also add another partition to your server and move data to this new location:
