- Plesk Obsidian for Linux
Unable to upgrade Plesk with the following error message:
CONFIG_TEXT: Migration failed: 18.0.31/2020-09-28-06-53-58_add_unique_guid_to_domains.php
Query failed: ALTER TABLE `domains` ADD UNIQUE KEY `guid` (`guid` ASC)
Duplicate entry '3ebe939b-c58c-4a56-a3e4-98750d90b157' for key 'guid'
Database inconsistency, two different domains have the same GUID.
Log into the server via SSH.
- Create a backup for psa database:
# plesk db dump psa > /root/psa.sql
- Execute the command below to find ID of the domains that have the same GUID:
# plesk db "select id from domains where guid='3ebe939b-c58c-4a56-a3e4-98750d90b157'\G;"
*************************** 1. row ***************************
*************************** 2. row ***************************
id: 338 - Manually generate a new GUID by changing several symbols of the GUID from the error, for example from:
CONFIG_TEXT: 3ebe939b-c58c-4a56-a3e4-98750d90b157
To
CONFIG_TEXT: 3ebe939b-c58c-4a56-a3e4-98750d90b378
- Using the command below, verify that the newly generated GUID is not assigned to any domain:
# plesk db "select guid,id from domains where guid='3ebe939b-c58c-4a56-a3e4-98750d90b378'\G;"
# - Run the command below to set newly generated GUID to one of the domains ID from step №3:
# plesk db "update domains set guid='3ebe939b-c58c-4a56-a3e4-98750d90b378' where id=137;"
- Re-run the Plesk upgrade.
