Let's Encrypt can not issue certificate for webmail only in Plesk if domain is hosted on another server: An SSL / TLS certificate could not be issued for example.com
4 comments
    Kaz Raad
    ok, so once you've done this — you just issue a certificate elsewhere and manually add it? because option 2 makes LetsEncrypt disappear as an option obviously ;)
    Yulia Plokhotnikova
    Hello @airplanenoise,
    This article is for situation when only webmail zone is hosted on the Plesk server. So to secure only webmail zone (for example, webmail.example.com), but not the main domain (example.com), the solution from this article should be applied. When you disable SSL/TLS Support option in Hosting Settings (resolution 2), Let's Encrypt is still available for securing webmail only:
    If you cannot issue an SSL for the main domain (for example, example.com, not webmail.example.com), you will need to search for another article as this one is not applicable here.
    Let me know the detailed issue description so that I try to find the solution for you.
    Kaz Raad
    thanks @... - yeah I can't issue the SSL for the main domain (example.com in your example) — cause it is hosted elsewhere. how can I secure webmail.example.com and other.example.com WITHOUT hosting example.com?
    Yulia Plokhotnikova
    Hello airplanenoise,
    Only webmail zone can be secured in Plesk when main domain is hosted on another server. Did you try to apply a solution from this article? Can you send the output of the same screen shots that i sent in the previous email so that I see your configuration?
    other.example.com cannot be secured on a Plesk side as main domain is not hosted in Plesk. Secure other.example.com on the same server where example.com is hosted.
