Diagnose & Repair tool detected issues with the database: Checking the Plesk database using the native database server tools
6 comments
    Stefano Sudati (Edited )
    Hello
    What should I do?
    plesk repair db
    RESULTS:
    Checking the Plesk database using the native database server tools .. [OK]
    Checking the structure of the Plesk database ........................ [OK]
    Checking the consistency of the Plesk database
    Inconsistency in the table 'apsResources' for the column registryId:
    There is no object in the 'apsc' database in the table
    'aps_registry_object' with UID =
    fbaf8e97-f8ca-424b-81ad-e1c247afd4ee .............................. [ERROR]
    Remove the corresponding rows from the table 'apsResources'? [Y/n]
    Can I safely cancel it? Or not?
    Julian Bonpland Mignaquy (Edited )
    Hi Stefano Sudati yes you can cancel the task safely. The warning tells you that there are inconsistencies in the apsc database.
    I recommend the following: backup psa and apsc via ssh:
    • plesk db dump psa > psa.sql
    • plesk db dump apsc > apsc.sql
    Repair all inconsistencies with the -y option:
    • plesk repair db -y -v
    -1
    Hi Julian
    Many Tnx
    Could you please write to me if it didn't work how to go back?
    1
    Stefano Sabino (Edited )
    The following domains are assigned to already removed IP addresses.
    Reassign the domains to existing IP addresses:  .................................................................. [ERROR]
    Error messages: 1; Warnings: 0; Errors resolved: 0
    Dosnt work
    Database problem not solved
    The operation failed with the following error: {"id":1,"cmd":"plesk repair db -y","type":"progress","message":"Checking the Plesk database using the native database server tools","level":0} {"id":1,"cmd":"plesk repair db -y","type":"success","message":"Checking the Plesk database using the native database server tools","level":0} {"id":2,"cmd":"plesk repair db -y","type":"progress","message":"Checking the structure of the Plesk database","level":0} {"id":2,"cmd":"plesk repair db -y","type":"success","message":"Checking the structure of the Plesk database","level":0} {"id":3,"cmd":"plesk repair db -y","type":"progress","message":"Checking the consistency of the Plesk database","level":0} {"id":4,"cmd":"plesk repair db -y","type":"error","message":"The following domains are assigned to already removed IP addresses. Reassign the domains to existing IP addresses:","level":1}
    Benjamin Wessel
    Hello Stefano Sabino,
    Please open a support request. We will then investigate this specific problem in a support ticket.
