Cannot change Node.js application root in Plesk: Class 'CommonPanel_Validate_FileSharing_FolderName' not found
3 comments
    Muneeb Ahmed
    Appreciated...
    info (Edited )
    This works, but I think nginx stop worked as espected, after apply this is not posible disable proxy mode in websites
    So,  domain -> proxy mode -> disable
    Plesk refresh with out error, but template not change
    Now try plesk repair web domain.com
    repair fail:
    [2020-10-14 14:10:13.121] ERR [panel] Apache config
    (16026774120.62980700) generation failed: Template_Exception:
    nginx: [emerg] unknown directive "passenger_enabled" in
    Got this error -> https://support.plesk.com/hc/en-us/articles/360020651393-Unable-to-start-NGINX-emerg-unknown-directive-passenger-enabled-
    Ivan Postnikov
    Hello info
    The cause is that Plesk does not support Phusion Passenger installed manually.
    It's better to avoid installing packages manually on servers managed by Plesk.
