- Plesk Onyx
The DNS template includes the element
<ip>
in the TXT record for SPF: -
IP address for SPF record is not changed when IP of subscription is changed:
This is a bug with id #PPPM-10032 which is going to be fixed in future updates.
As a workaround, apply these steps:
Change SPF records for all domains of the subscription manually under Domains > example.com > DNS Settings > example.com. (TXT):
CONFIG_TEXT: v=spf1 +a +mx +a:192.0.2.2 -all
