Domain
example2.com
shows the following error message after moving it to another subscription (example.com) in Domains > example2.com > Move Domain:CONFIG_TEXT: 403 Forbidden
You don't have permission to access / on this server.
Server unable to read htaccess file, denying access to be safe -
The following error appears in Domains > example2.com > Logs:
CONFIG_TEXT: [core:crit] (13)Permission denied: AH00529:/var/www/vhosts/example.com/example2.com/httpdocs/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable and that '/var/www/vhosts/example.com/example2.com/httpdocs/' is executable, referer: https://example2.com/
Repairing permissions for
example2.com
shows:CONFIG_TEXT: There is incorrect ownership on some items in the WWW root directory of the domain 'example2.com' ........................................... [ERROR]
- Incorrect group of /var/www/vhosts/example.com/example2.com/httpdocs:
expected is psaserv (1002), actual is psacln (1003) -
The ownership of the
httpdocs
folder got changed after moving:# ls -ld /var/www/vhosts/example.com/example2.com/httpdocs/
drwxr-x--- 2 user psacln 4096 Sep 2 09:16 /var/www/vhosts/example.com/example2.com/httpdocs/Note: There is psaserv expected instead of psacln.
Product issue:
- #PPPM-12251 "Moving the main domain of a subscription to a different subscription now sets the correct ownership of the domain’s document root directory."
Fixed in:- Plesk Obsidian 27 October 2020 (Linux)
Workaround
If update is not possible for some reason you may try the following
As a workaround until the bug is fixed, repair permissions:
Connect to the server via SSH
Execute the following command for the affected domain:
# plesk repair fs example2.com -y
if it does not help:
# chmod o+x /var/www/vhosts/example.com/example2.com/httpdocs/
2 comments
one of my page of manga Demon Tyrant Love is not going well. It takes too much load time.
Can i do this for my website: voicemailgreetings.me?
