Unable to create domain alias or Plesk upgrade fails: Duplicate entry for key 'guid'
3 comments
    Marcio Nunes
    -bash: syntax error near unexpected token `newline'
    Gilles Dumont
    We are getting the same error -bash: syntax error near unexpected token `newline' while executing:
    plesk db -Ne "SELECT guid, count(guid) FROM domains GROUP BY guid HAVING COUNT(guid) > 1" | while read G C; do echo "> DUPLICATED GUID: $G"; for ((i=0;i<(C-1);i++)); do plesk db -Ne "SELECT id, name FROM domains WHERE guid = '$G' limit 1" | while read I D; do plesk db -Ne "UPDATE domains SET guid = UUID() WHERE id = '$I'"; echo "- FIXED: $D"; done; done; done; echo "> COMPLETED"
    Ivan Postnikov
    Hello Marcio Nunes
    The script has worked fine on my test server. There could have been some issue with copying the code.
    The script I've used:
    Screenshot of it working:
