If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Unable to create domain alias or Plesk upgrade fails: Duplicate entry for key 'guid'
3 comments
    Marcio Nunes
    -bash: syntax error near unexpected token `newline'
    Ivan Postnikov
    Hello Marcio Nunes
    The script has worked fine on my test server. There could have been some issue with copying the code.
    The script I've used:
    plesk db -Ne "SELECT guid, count(guid) FROM domains GROUP BY guid HAVING COUNT(guid) > 1" | while read G C; do echo "> DUPLICATED GUID: $G"; for ((i=0;i<(C-1);i++)); do plesk db -Ne "SELECT id, name FROM domains WHERE guid = '$G' limit 1" | while read I D; do plesk db -Ne "UPDATE domains SET guid = UUID() WHERE id = '$I'"; echo "- FIXED: $D"; done; done; done; echo "> COMPLETED"
    Screenshot of it working:
    Gilles Dumont
    We are getting the same error -bash: syntax error near unexpected token `newline' while executing:
