NextCloud or Typo3 applications are not accessible with webbrowser, one of the following HTTP status codes is shown:
CONFIG_TEXT: Server Error 500 Internal Server Error
CONFIG_TEXT: Server Error 503 Service Temporarily Unavailable
CONFIG_TEXT: Server Error 502 Bad Gateway
Plesk PHP 7.2.32 or 7.3.20 is configured in Domains > example.com > PHP Settings > PHP version
The following errors are shown in the Plesk PHP log files:
CONFIG_TEXT: WARNING: [pool example.com] child 27146 exited on signal 4 (SIGILL) after 0.649431 seconds from start
The following error is shown in the log files
/var/log/messages
(CentOS-based) or/var/log/syslog
(DebianOS-based):CONFIG_TEXT: kernel: traps: php-fpm[27146] trap invalid opcode ip:71222d sp:7ffcbc457820 error:0 in php-fpm[400000+400000]
Running the following command shows the same error message:
# /opt/plesk/php/7.2/bin/php -r "echo 'Argon2i hash: ' . password_hash('pwd', PASSWORD_ARGON2I) . PHP_EOL;"
Illegal instruction# /opt/plesk/php/7.3/bin/php -r "echo 'Argon2i hash: ' . password_hash('pwd', PASSWORD_ARGON2I) . PHP_EOL;"
Illegal instruction
Product issues:
#PPPM-12210 "Argon2 usage in PHP 7.2 and 7.3 causes crash due to "Illegal instruction""
Fixed in:- Plesk Obsidian 27 July 2020
Note: If PHP downgrade was applied with script for Debian 9 or Ubuntu 16 follow these steps:
To undo workaround, perform these steps:
Connect to the server via SSH
Run this command:
# rm -f /etc/apt/preferences.d/plesk-php73 /etc/apt/preferences.d/plesk-php72
Enable Plesk updates:
# plesk bin server_pref -u -autoupdates true
1 comment
Benjamin Wessel, thanks só much for posting this. Was deep down the rabbit hole to figure out why the hell my NextCloud instance wasn't working anymore.
I was getting "502, Bad Gateway", returns from NGINX on my browser, while running PHP-FPM 7.3. But also on Apache or PHP-FPM 7.2 the same error showed up. It puzzled me that with wrong logins it kept serving me pages, but with correct logins in the webinterface of Nextcloud, it gave me the 502, Bad Gateway error.
Man oh man, I was having this for two weeks and in some evenings trying to fix it, unable to. Until this post came along. Thx a bunch.
I added some terms in my comment like the Bad Gateway, hopefully others will find this post as well. Or even better: Plesks brings out a fix...
