- Plesk for Windows
Unable to issue an SSL certificate for a domain with any of the following errors:
CONFIG_TEXT: Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/6955924289. Details: Type: urn:ietf:params:acme:error:connection Status: 400 Detail: Fetching http://www.acme-challenge.localhost/.well-known/acme-challenge/VZ0HZWatiUiZ_qdbOF0P8qWVhkUx44frNXXoQFsX79Q: Invalid hostname in redirect target, must end in IANA registered TLD
CONFIG_TEXT: Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/6658802176.
Details:
Type: urn:ietf:params:acme:error:unauthorized
Status: 403 -
Upon opening
https://example.com/.well-known/acme-challenge/test.txt
in the browser the following message is shown:PLESK_INFO: 404 - File or directory not found.
Requested URL http://acme-challenge.localhost:80/test.txt
Physical Path %plesk_dir%\var\acme-challenge\test.txt -
Common challenge directory feature of SSL It extension is enabled:
C:\> plesk ext sslit --common-challenge-dir -info
- Available: true
- Enabled: true
Broken common challenge directory feature of SSL It extension.
Connect to the server via RDP.
Disable common challenge directory by executing the command:
C:\> plesk ext sslit --common-challenge-dir -disable
Issue certificate in Domains > example.com > SSL/TLS Certificates
Re-enable common challenge directory by executing the command:
C:\> plesk ext sslit --common-challenge-dir -enable
