- Plesk Onyx for Linux
Web statistics for a domain is updated several times during Daily Maintenance.
Web statistics executor utility is invoked during the task ExecuteStatistics despite the fact that the task executed with
no-webstat
option:CONFIG_TEXT: root 2740 0.0 0.1 413548 45164 ? S 03:05 0:00 | \_ /usr/bin/sw-engine -c /opt/psa/admin/conf/php.ini /opt/psa/admin/plib/DailyMaintainance/script.php
root 4815 0.0 0.0 4504 704 ? S 03:47 0:00 | \_ sh -c '/opt/psa/admin/bin/php' '/opt/psa/admin/plib/DailyMaintainance/task-script.php' 'ExecuteStatistics' '--period=daily'
root 4816 0.0 0.1 411512 42576 ? S 03:47 0:00 | \_ /usr/bin/sw-engine -c /opt/psa/admin/conf/php.ini /opt/psa/admin/plib/DailyMaintainance/task-script.php ExecuteStatistics --period=daily
root 4825 0.0 0.0 4504 704 ? S 03:47 0:00 | \_ sh -c /opt/psa/admin/sbin/statistics --no-webstat
root 4826 0.0 0.1 415596 47096 ? S 03:47 0:02 | \_ /usr/bin/sw-engine -c /opt/psa/admin/conf/php.ini /opt/psa/admin/sbin/statistics --no-webstat
root 10186 0.4 0.1 448944 75684 ? S 08:49 0:07 | \_ /usr/bin/sw-engine -c /opt/psa/admin/conf/php.ini /opt/psa/admin/sbin/statistics --calculate-list --domain-ids 1550,1551,1552,1553,1554,1555,1556,1557,1558,1559,1560,1561,1562,1563,1564,1565,1566,1567,1568,1569,1570,1571,1572,1573,1574,1575,1576,1577,1578,1579,1580,1581,1582,1583,1584,1585,1588,1589,1590 no-webstat
Plesk bug with ID #PPPM-9875 which was fixed in Plesk Onyx 17.9 Preview 10.
Upgrade to the latest Plesk version.
If upgrade is not possible for some reason, apply the following
workaround
Connect to Plesk server via SSH
Back up the file /usr/local/psa/admin/plib/api-common/StatisticsCollector.php:
# mv /usr/local/psa/admin/plib/api-common/StatisticsCollector.php{,.orig}
Download the custom fix, unarchive it and replace the backed up file with the custom fix:
# wget https://plesk.zendesk.com/hc/article_attachments/360020947594/StatisticsCollector.tar.gz
# tar -zxvf ./StatisticsCollector.tar.gz
# mv ./StatisticsCollector.php /usr/local/psa/admin/plib/api-common/
