[FIXED BUG] mod_rewrite stopped working. All pages on WordPress sites show 404
12 comments
    Juanjo Sánchez
    ¡IT DOESN'T WORK!
    Después de actualizar WordPress Toolkit a 4.8.1 ejecuto plesk repair web y en todas las webs del servidor dejan de funcionar los redireccionamientos, esto es un problema muy muy grave.
    Haumanto
    Re-apply these security measures will break.
    • enable bot protection
    • block author scan
    I had to leave those 2 unsecured for the site to work.
    Furthermore, I think subdomain within the same subscription which doesn't have WP but still use .htaccess rewrite rule also breaks because of this bug and don't know how to fix that particular subdomain because it isn't WP site, thus no WPToolKit.
    porta nicolas
    I have 404 errors on all the pages of several sites located in a sub-domain.
    I tested the "workaround" solution but in my case it does not solve the problem.
    I am on WPTOOLKIT version 4.8.1-3636 and 18.0.26 PLESK.
    1
    Denit Support
    A faster way to do it 1 site at a time is the following:
    So let's do the following it then, let's revert all changes done on the instances.
    1. Extensions > Wordpress Toolkit > Installation Tab > Security > Select All instances > Revert > Enable hotlink protection, Block authors scan and Enable bot protection
    2. Run plesk repair web -y on CLI
    Anton Maslov
    Hi all,
    Please execute also web server reconfiguration:
    Tools & Settings > Diagnose & Repair > Web & FTP Servers > Repair
    Or the same from SSH:
    plesk repair web -y
    porta nicolas
    I just performed the procedure on ALL sites, then I execute  "plesk repair web -y" command via SSH and it works now.
    Thanks Anton
    2
    Ion Vrinceanu
    This solution is only for vhosts that have WP Toolkit. What about vhosts that have installed WordPress without WP Toolkit?
    1
    Anton Maslov
    Hi Ion, Wordpress domains without WP Toolkit can be affected in case there is another domain under the same subscription which has WP Toolkit instance installed. The same steps to disable security measures and do reconfiguration should also solve instances not from WP Toolkit as well.
    Ion Vrinceanu
    Ahh, there was a subdomain I've missed. Thanks, this fixed the issue.
    Victor Amil
    This issue is happening also in Plesk Onyx.
    After a upgrade from Plesk Onyx to Obsidian its needed to follow this instructions and upgrade the WordPress Toolkit.
    Thanks for the fix.
    Tony (Edited )
    wow, it's been a nightmare trying to troubleshoot this across two servers overnight.  trying this fix now! the only workaround i had found was switching php from FPM served by Apache to FPM served by Nginx.
    Yay- it worked to fix the first domain I tried it on, Denit Support, thanks!
    Rob Marlbrough
    This was driving me nuts, only affecting one site out of many, and I use WordPress toolkit on them all, but perhaps bot protection or block authors was not enabled, not sure.
    The updated toolkit resolved the issue for me!
