If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Unable to issue Let's Encrypt certificate when Let's Encrypt extension is in standalone mode
2 comments
    Peter Milford
    every update to Plesk I have to go rerun this to fix this error.  Just had to run it again after updating to 18.0.38 this last week. SSLIT is disabled.
    Yulia Plokhotnikova
    Hello @Peter Milford,
    Could you try to enable SSLIt extension instead or remove it and then disable the Common Challenge Directory ( 1st or 3rd solution)?
