Plesk for Linux
kb: technical
ABT: Group A
Advanced Monitoring shows the error in Plesk:
PLESK_INFO: login.OAuthLogin(missing saved state)
The following errors persist in the
/var/log/grafana/grafana.log
:CONFIG_TEXT: lvl=eror msg="Failed to look up user based on cookie" logger=context error="user token not found"
This issue is related to the changes applied to the cookie path from the Grafana vendor's side. It has been reported to Grafana Team and has already been addressed.
Install the latest available system packages updates to update grafana to the latest version.
If an update is not possible for some reason, as a workaround, delete browser cookies for "grafana_session".
