kb: technical
Plesk Obsidian for Linux
Plesk Obsidian for Windows
- Plesk Obsidian for Linux
- Plesk Obsidian for Windows
Plesk Web Pro or Web Host Editions are in use (the Editions that supports Service Provider view)
Under the main menu, there is no UI element Change view:
The Change View element was closed by pressing the X button.
Once done it will not be shown again.
In order to return the UI element back, perform the following operations:
Execute the command below (start a Command Prompt on Windows):
# plesk db "DELETE FROM cl_param WHERE param = 'view_switcher_hidden'"
Switching views without returning the UI element:
Go to Tools & Settings > Interface Management
Choose the necessary view under the option Select your interface:
1 comment
The problem not yet fixed
