How to enable Web Presence Builder for all websites?
Web Presence Builder option should be available for all domains after Web Presence Builder installed if it is not restricted on Service Plan or Subscription level.
Log in to Plesk
Check that Web Presence Builder is installed by opening Tools & Settings > Updates and Upgrades > Add/Remove components:
If Web Presence Builder is installed, check that the publishing feature is available for Plesk license at Tools & Settings > License Management. If the parameter Sites published with Web Presence Builder equals zero, customers will not be able to use Web presence Builder.
If the Web Presence Builder limit on the license is not zero, the ability to edit the site is determined by the service plan. Go to Service Plans > (Select service plan) and set the desired limit for the Sites published with Web Presence Builder parameter:
A subscription inherits the settings and limits of its service plan. However, subscription limits can be customized. If the Presence Builder button is not shown on some domains, check that the limit of the Sites published with Web Presence Builder parameter has not been changed. Go to Home > Subscriptions > (Select subscription) > click on the "Customize" button (Check the limit for the "Sites published with Web Presence Builder" parameter)
Please note that the Web Presence Builder option available in the Active list view for customers. If Web Presence Builder is not shown for some customers:
Log in as a customer
Go to Websites & Domains, click the wrench icon, and then check the View Mode:
Please vote for functionality to add Web Presence Builder option to Dynamic list view: Enable Web Presence Builder option from Dynamic List in Plesk Obsidian
