If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Why ServerShield by CloudFlare is not available for installation or purchase in Plesk?
3 comments
    Arez Abdulqadir
    Is there any update on a new integration with cloudflare or alternative options?
    Andrew Stewart
    Hello,
    Will an existing ServerShield migrate across to a new server and Plesk installation?
    Ivan Postnikov
    Hello Arez Abdulqadir
    No news at the moment. You may still use CloudFlare just you will need to set the integration manually on CloudFlare side.
