Why ServerShield by CloudFlare is not available for installation or purchase in Plesk?
5 comments
    Arez Abdulqadir
    Is there any update on a new integration with cloudflare or alternative options?
    Ivan Postnikov
    Hello Arez Abdulqadir
    No news at the moment. You may still use CloudFlare just you will need to set the integration manually on CloudFlare side.
    Andrew Stewart
    Hello,
    Will an existing ServerShield migrate across to a new server and Plesk installation?
    Markus L.
    I’m currently looking into creating a free open-source community plugin for basic Cloudflare integration and I hope I will be able to publish it on the plesk store later on.
    Currently I have the following features in mind/partially complete:
    - Domain-binding via Cloudflare API (key and zone)
    - Automated Cloudflare Origin-SSL
    - Dynamic support for CF_CONNECTING_IP on connected domains
    - Authenticated-Origin-pull support and automated custom certificate zone enrollment
    - Support for dynamic DNS binding over Cloudflare
    - Integration with various firewalls available for Plesk to better customize profiles
    - Integration into Plesk recommendation plugin
    - Integration for auth and provider with Cloudflare teams
    But at this point I am still learning the limits of what I am able to do here; so this will probably take some time to complete.
    1
    Oliver Heller
    Really? Honestly, there are Plesk extensions that simply have to be there. A Cloudflare extension is one of them.
    What you forgot to do in your explanation is to include a link to a complete guide on how to set up Cloudflare for multiple WordPress sites.
    Even free management panels like CyberPanel have a global Cloudflare extension for all managed sites included.
    best Regards
    Oliver
