Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
How to manage Fail2Ban and its jails in Plesk for Linux
3 comments
    Roney Ngala
    How do I disable the email Notifications (they are too many, after every minute!) but still maintain the Fail2ban running in the server?
    Email notification sample: "The IP 51.79.74.171 has just been banned by Fail2Ban after 5 attempts against default."
  • Hi Roney Ngala,
    Such setting is not available from Plesk yet, but it's something you can manage directly at Fail2Ban: /etc/fail2ban/action.d/sendmail.conf
    As of now, I would recommend you to vote for this feature request.
    Atet Sugiharto
    Hi everyone,
    My Plesk Obsidian Fail2Ban could not working after I did change vhosts directory. I try to enable it but no error created. It's just disable again.
    SELinux in permissive mode.
    Anyone can advice please.
