If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Plesk domain is not resolved from some countries: DNS_PROBE_FINISHED_NXDOMAIN
3 comments
    Veasna Or
    Hello, I need your assistance checking on my errors.
    This site can’t be reached
    Check if there is a typo in www.cambodia24.com.
    • If spelling is correct, try running Windows Network Diagnostics.
    Thanks
    DyonatanDias
    managed to solve?
    I have the same problem.
    Hirusha Cooray
    Make sure DNS port 53 is open.
