[FIXED BUG] Daily Maintenance Task fails one task and not executing other in the queue on Plesk server
2 comments
    Bob B
    Hello,
    I'm getting the referenced error message.  If it is caused by a daily scheduled task that fails, how do I determine which of the daily tasks is failing?
    Best Regards,
    Bob
    Anton Maslov
    Hello Bob,
    1. Enable debug for Plesk
    2. Run daily Maintenance manually:
    # plesk daily
    3. It will write what task started and you'll know which one fails, e.g. below entries indicates that Plesk start checking for updates:
    [2019-05-25 07:22:17.248] INFO [panel] Starting: Daily Maintainance
    [2019-05-25 07:22:17.250] INFO [panel] == Task run Check for updates: '/usr/local/psa/admin/bin/php' '/usr/local/psa/admin/plib/DailyMaintainance/task-script.php' 'CheckForUpdates' '--period=daily'
    [2019-05-25 07:22:17.397] INFO [panel] == Begin Check for updates
