- Plesk for Windows
Plesk Administrator receives notifications from Advanced Monitoring:
PLESK_INFO: [Alerting] Apache & php-fpm memory usage
Memory usage status is critical!
PLESK_INFO: [Alerting] IIS memory usage
PLESK_INFO: [Alerting] MySQL memory usage
PLESK_INFO: [Alerting] Physical and virtual memory usage
Memory consumed by the process mentioned in the warning exceeds the threshold configured in Advanced Monitoring settings.
If the threshold is lower than presumable service memory consumption (by default it is set to 20%), increase the threshold to a greater value:
Go to Advanced Monitoring > Settings > Thresholds.
Increase the threshold value for memory usage of the service in question.
Apply the changes.
Alternatively, allocate more RAM to the server. For assistance, contact your hosting provider.
