kb: fixed
kb: bug
ABT: Group B
Plesk Obsidian for Linux
- Plesk Obsidian for Linux
Unable to import site Subscriptions > examples.com > Website Importing > OK.
Nothing happens. It just stay on the same page with "OK" button.
Product issue:
#PMT-4694 "Website import can now be again launched."
Fixed in:- Site Import 1.4.3 20 February 2020
Workaround
If update is not possible for some reason you may try the following
workaround
As a workaround:
- Login to Plesk
- Go to Subscriptions > examples.com > Website Importing > Switch to advanced mode.
Specify:
Connection type - FTP
Get list of files mode - FTP/SSH
Way to transfer files - Automatic
FTP server charset - UTF-8
1 comment
The FTP server charset field highlights in red and says that the field is not supported, but the workaround still works.
