Awstats *.txt data files (such as ones stored under /var/www/vhosts/system/example.com/statistics/webstat-ssl) are kept longer than set within the TTL of the Domain/Server.
Plesk bug #PPPM-10655, which will be fixed in future product updates.
For GDPR compliant environment, use Webalizer with IP addresses anonymization.
