[BUG] Old AWstats txt data files are not removed with web statistics cleanup
2 comments
    Bob B
    Hello,
    Until this is fixed, is there any chance you folks could release a script, that I could run, manually, to remove the very old files (and directories) in "/var/www/vhosts/system/example.com/statistics/webstat" and "/var/www/vhosts/system/example.com/statistics/webstat-ssl" for each subscription?
    Customers are going over their quotas because these large files are going back many years.  The subscription I'm looking at right now has these files going back a decade, to 2010.
    Also, where do I find the setting for "TTL of the Domain/Server" in regards to AWStats?
    Best Regards,
    Bob
    Denis Bykov
    Hello Bob,
    Thank you for the questions.
    I've updated the article with additional details and the script which can be used as a w/a for AWStats.
    1
