Unable to send mail message via sendmail command line utility:
# echo "Subject: sendmail test" | sendmail -v johndoe@example.com
plesk sendmail[21306]: my_popen(): execve(/usr/lib64/plesk-9.0/sendmail/sendmail.postfix) failed: No such file or directory [2]
plesk sendmail[21306]: Unable to execute MTA
plesk sendmail[21305]: sendmail unsuccessfully finished with exitcode 70
CONFIG_TEXT: /usr/sbin/sendmail: 1: /usr/sbin/sendmail: Syntax error: Unterminated quoted string
CONFIG_TEXT: /usr/sbin/sendmail: cannot execute binary file: Exec format error
CONFIG_TEXT: plesk sendmail[20188]: cannot create temporary file - (13) Permission denied
plesk sendmail[20188]: Unable to save stdin content to temporary file -
The same error can be found on
/var/log/maillog
file.
File/usr/lib64/plesk-9.0/sendmail/sendmail.postfix
is missing or corrupted.
- Determine what mail server installed: Plesk > Tools & Settings > Mail Server Settings:
Connect to the server via SSH;
Download and reinstall suitable for environment and installed Plesk version package from Plesk repository:
"plesk-mail-pc-driver" (for Postfix mail server)
"plesk-mail-qc-driver" (for Qmail mail server)example for Debian-based OS:# wget http://autoinstall.plesk.com/PSA_18.0.31/dist-deb-Ubuntu-20.04-x86_64/opt/maildrivers/plesk-mail-pc-driver_18.0-v.ubuntu.20.04+p18.0.31.2+t201127.1705_amd64.deb
Remove the current package:
# dpkg -P --force-all plesk-mail-pc-driver
Install the downloaded one:
# dpkg -i plesk-mail-pc-driver_18.0-v.ubuntu.20.04+p18.0.31.2+t201127.1705_amd64.deb
example for RedHat-based OS:# wget http://autoinstall.plesk.com/PSA_18.0.31/dist-rpm-CentOS-8-x86_64/opt/maildrivers/plesk-mail-pc-driver
# rpm -ev plesk-mail-pc-driver
# rpm -ivh plesk-mail-pc-driver-18.0-2.centos.8+p18.0.31.2+t201127.1705.x86_64.rpm
