- Plesk Onyx for Linux
Warning: The article is applicable only to Plesk servers with operating systems: CentOS 6, Red Hat Enterprise Linux 6, CloudLinux 6.
The utility
pci_compliance_resolver
was used:# plesk sbin pci_compliance_resolver --enable <service>
After that, weak 3DES ciphers are still used, for example:
# nmap -sV --script ssl-enum-ciphers -p 993 plesk.example.com
PORT STATE SERVICE VERSION
993/tcp open ssl/imap Courier Imapd (released 2017)
| ssl-enum-ciphers:
| TLSv1.1:
| ciphers:
| TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA (secp256r1) - C
| TLS_RSA_WITH_3DES_EDE_CBC_SHA (rsa 2048) - C
| warnings:
| 64-bit block cipher 3DES vulnerable to SWEET32 attack
| TLSv1.2:
| ciphers:
| warnings:
|_ least strength: C
The official fix from OpenSSL was differently ported by Red Hat to RHEL 6 (and thus, to CentOS 6 and other operating systems based on RHEL 6).
Because of that, 3DES ciphers are still used when the keyword HIGH
is specified in the cipher list.
Plesk bug PPPM-10040 was created to remove the weak ciphers from the list set by pci_compliance_resolver
. It is planned to be fixed in one of the future Plesk updates.
Until the bug is fixed, use the following workaround:
Note: The workaround can be used only by server administrator. In case there is no administrative SSH or RDP access to the server, contact the server administrator or server provider.
Connect to the server using SSH.
Delete the ciphers
EECDH+HIGH
andHIGH
from the cipher list of the corresponding service:sw-cp-server (special nginx for Plesk)# sed -i s/:HIGH:/:/ /etc/sw-cp-server/conf.d/ssl.conf && sed -i s/:EECDH+HIGH:/:/ /etc/sw-cp-server/conf.d/ssl.conf
# service sw-cp-server reloadnginx# sed -i s/:HIGH:/:/ /etc/nginx/conf.d/ssl.conf && sed -i s/:EECDH+HIGH:/:/ /etc/nginx/conf.d/ssl.conf
# service nginx reloadApache# sed -i s/:HIGH:/:/ /etc/httpd/conf.d/ssl.conf && sed -i s/:EECDH+HIGH:/:/ /etc/httpd/conf.d/ssl.conf
# service httpd reloadCourier-IMAP# sed -i s/:HIGH:/:/ /etc/courier-imap/imapd-ssl && sed -i s/:EECDH+HIGH:/:/ /etc/courier-imap/imapd-ssl
# service courier-imaps reload# sed -i s/:HIGH:/:/ /etc/courier-imap/pop3d-ssl && sed -i s/:EECDH+HIGH:/:/ /etc/courier-imap/pop3d-ssl
# service courier-pop3s reloadDovecot# sed -i s/:HIGH:/:/ /etc/dovecot/conf.d/11-plesk-security-ssl.conf && sed -i s/:EECDH+HIGH:/:/ /etc/dovecot/conf.d/11-plesk-security-ssl.conf
# service dovecot reloadPostfix# sed -i s/:HIGH:/:/ /etc/postfix/main.cf && sed -i s/:EECDH+HIGH:/:/ /etc/postfix/main.cf
# service postfix reloadProFTPd# sed -i s/:HIGH:/:/ /etc/proftpd.d/ssl.conf && sed -i s/:EECDH+HIGH:/:/ /etc/proftpd.d/ssl.conf
