- Plesk Onyx for Linux
The following error message occurs on an attempt to open phpMyAdmin in Domains > example.com > Databases or in Tools & Settings > Database Servers >
next to the MySQL server name:
CONFIG_TEXT: Error during session start; please check your PHP and/or webserver log file and configure your PHP installation properly. Also ensure that cookies are enabled in your browser.
session_start(): open(SESSION_FILE, O_RDWR) failed: No such file or directory (2)
session_start(): Failed to read session data: files (path: ./tmp/session) -
The following entry is found in
/var/log/syslog/
:CONFIG_TEXT: GenerationTree mysql[1457]: ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
SessionSavePath
is set to./tmp/session
:Debian, Ubuntu:
# grep -rin 'SessionSavePath' /opt/psa/admin/htdocs/domains/databases/phpMyAdmin/libraries/config.default.php
716:$cfg['SessionSavePath'] = './tmp/session';CentOS:
# grep -rin 'SessionSavePath' /usr/local/psa/admin/htdocs/domains/databases/phpMyAdmin/libraries/config.default.php
716:$cfg['SessionSavePath'] = './tmp/session'; -
phpMyAdmin package is not configured:
# dpkg -l | grep -i phpmyadmin
iU psa-phpmyadmin 4.8.3-ubuntu16.04.build1708180919.15 all MySQL web administration tool adapted for Plesk Onyx
The package psa-phpmyadmin
is not configured.
The proper SessionSavePath
should be /opt/psa/var/phpMyAdmin/session
for Debian/Ubuntu or /usr/local/psa/var/phpMyAdmin/session
for CentOS.
Connect to the server using SSH.
Configure
psa-phpmyadmin
package:# dpkg-reconfigure psa-phpmyadmin
Verify that the path is proper now:
# grep SessionSavePath /opt/psa/admin/htdocs/domains/databases/phpMyAdmin/libraries/config.default.php
$cfg['SessionSavePath'] = '/opt/psa/var/phpMyAdmin/session';
Connect to the server using SSH;
Go to http://autoinstall.plesk.com and download package with the PHPMyAdmin of the required version in PSA<Plesk panel version> > dist-rpm<OS version> > psa-phpmyadmin<> package (example for
psa-phpmyadmin-4.8.3-cos7.build1708180919.15.noarch.rpm
):# wget http://autoinstall.plesk.com/PSA_17.8.11/dist-rpm-CentOS-7-x86_64/base/psa-phpmyadmin-4.8.3-cos7.build1708180919.15.noarch.rpm
Reinstall the
psa-phpmyadmin
package:# rpm -Uvh psa-phpmyadmin-4.8.3-cos7.build1708180919.15.noarch.rpm --force
# grep 'SessionSavePath' /usr/local/psa/admin/htdocs/domains/databases/phpMyAdmin/libraries/config.default.php
$cfg['SessionSavePath'] = '/usr/local/psa/var/phpMyAdmin/session';
