[FIXED BUG] It is not possible to log into phpMyAdmin: failed to read session data: files (path: @@PMA_TEMP_DIR@@/session)
9 comments
    Daniel Joos
    Bulat Tsydenov
    We run into the same issue as Sharul Hafiz and updated to the latest version. Phpmyadmin is still unavailable. Should we reach out to the support as well? Any help is welcome!
    Benoit Boucher
    For myself, Plesk bug after an update yesterday. I couldn't see the username and password credential so to fix this problem, I made a "plesk repair installation" in ssh on centos 7
    After that, I got this phpMyAdmin error but this workaround didn't fix the problem.
    I finally solve my problem with this since /tmp/session seems to have been deleted after update/plesk repair
    mkdir /usr/local/psa/admin/htdocs/domains/databases/phpMyAdmin/tmp
    mkdir /usr/local/psa/admin/htdocs/domains/databases/phpMyAdmin/tmp/session
    chmod 777 /usr/local/psa/admin/htdocs/domains/databases/phpMyAdmin/tmp
    chmod 777 /usr/local/psa/admin/htdocs/domains/databases/phpMyAdmin/tmp/session
    Anton Maslov
    Hello Ruben Wijkhuise your rpm database corrupted, you need to rebuild that using instructions we have
    Sharul Hafiz
    I tried to do this on Plesk 18, but not available on autoinstall.plesk.com. Need to reinstall phpmyadmin on plesk obisidian.
    Anton Maslov
    Alberto Gonzalez Hi, please create a ticket to check the issue.
    Bulat Tsydenov
    @Sharul Hafiz
    Please make sure, you have Plesk Obsidian 18.0.20, there are some phpmyadmin improvements in this Plesk version. If it is still not working with the latest update of Plesk Obsidian, I recommend you contacting our support at https://support.plesk.com/hc/en-us/requests/new
    Alberto Gonzalez
    Hi.. I have the same problem. And the workaround not work.
    Debian 9.12
    Plesk Obsidian 18.0.23 Update #4
    dpkg -l | grep -i phpmyadmin
    ii psa-phpmyadmin 4.9.0.1-v.debian.9+p18.0.23.4+t200206.1432 all MySQL web administration tool adapted for Plesk
    dpkg-reconfigure psa-phpmyadmin
    prompt return
    And run:
    grep SessionSavePath /opt/psa/admin/htdocs/domains/databases/phpMyAdmin/libraries/config.default.php
    Result:
    * @global integer $cfg['SessionSavePath']
    $cfg['SessionSavePath'] = './tmp/session';
    No changes.
    Could you help me please?
    Best regards
    Alberto
    Ruben Wijkhuise
    I have the same problem with phpmyadmin.
    when executing:
    rpm -Uvh psa-phpmyadmin-4.9.0.1-2.centos.7+p18.0.23.3+t200130.1239.noarch.rpm --force
    I get:
    fout: rpmdb: BDB0113 Thread/process 30947/140010580232320 failed: BDB1507 Thread died in Berkeley DB library
    fout: db5 fout(-30973) van dbenv->failchk: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery
    fout: cannot open Packages index using db5 - (-30973)
    fout: cannot open Packages database in /var/lib/rpm
    waarschuwing: psa-phpmyadmin-4.9.0.1-2.centos.7+p18.0.23.3+t200130.1239.noarch.rpm: Header V4 DSA/SHA1 Signature, key ID 914bdf7e: NOKEY
    Lev Iurev
    @Daniel Joos It is not required. Our developers have confirmed a bug in the product. They are working on the fix, for a while please apply the workaround described in the article.
