[FIXED BUG] It is not possible to log into phpMyAdmin: failed to read session data: files (path: @@PMA_TEMP_DIR@@/session)
4 comments
    Sharul Hafiz
    I tried to do this on Plesk 18, but not available on autoinstall.plesk.com. Need to reinstall phpmyadmin on plesk obisidian.
    Bulat Tsydenov
    @Sharul Hafiz
    Please make sure, you have Plesk Obsidian 18.0.20, there are some phpmyadmin improvements in this Plesk version. If it is still not working with the latest update of Plesk Obsidian, I recommend you contacting our support at https://support.plesk.com/hc/en-us/requests/new
    Daniel Joos
    Bulat Tsydenov
    We run into the same issue as Sharul Hafiz and updated to the latest version. Phpmyadmin is still unavailable. Should we reach out to the support as well? Any help is welcome!
    Lev Iurev
    @Daniel Joos It is not required. Our developers have confirmed a bug in the product. They are working on the fix, for a while please apply the workaround described in the article.
