Plesk for Linux
kb: how-to
ABT: Group A
How to make Fail2Ban monitor a specific website in Plesk and block failure login attempts?
Go to Tools & Settings > IP Address Banning (Fail2Ban) > switch to the Jails tab > click Add Jail.
On the Add Jail page, fill in the fields:
Filter: apache-auth
Action field: iptables-multiport[name="website-login", port="http,https,7080,7081"]
Log path: /var/www/vhosts/system/example.com/logs/error_log
/var/log/httpd/*error_logNote: Replace example.com in the above log path with your domain name.
Click OK.
Witch to the Settings tab and make sure Enable intrusion detection is enabled.
Once the jail is enabled, all banned IP addresses (if any) will appear on the Banned IP Addresses tab.
