Plesk for Windows
Plesk for Linux
kb: technical
ABT: Group B
- Plesk for Windows
- Some functionalities are absent in Plesk interface (Extensions button in the left panel, Subscriptions menu, PHP Settings for a domain, links in Tools & Settings, etc.);
Change View option to change interface view from Power User to Service Provider is missing in the left bottom corner;
Plesk administrator interface management is locked by enabled Restricted Mode (on Plesk Obsidian) / Custom View (on Plesk Onyx) in Tools & Settings > Restricted Mode Settings/Custom View Settings;
Settings.
Log into Plesk go to Tools & Settings > Restricted Mode Settings and untick Enable Restricted Mode:
Command line solution
- Connect to the server via SSH/RDP
Run the following command on Linux or Windows server:
# plesk bin poweruser --off -lock false
In case Plesk Web Admin edition is in use, the command should be:
# plesk bin poweruser --on -simple false -lock false
