Subscription is not locked when PHP settings are changed
10 comments
    Manuel Kälin
    Hi
    does this only belong to 17.5?
    So if we upgrade to 17.8, it is fixed?
    Kind Regards
    Artyom Baranov
    @Manuel Kälin,
    Hello! This bug affects Plesk 17.8 as well, we have updated the "Applicable to" field accordingly.
    Thank you for noticing!
    Manuel Kälin
    Hi
    The application to has been reverted?
    When will these problems be fixed?
    Kind Regards
    Ivan Postnikov
    Hello @Manuel,
    Thank you for notice, version 17.8 was added back to applicable. Will check how was it reverted.
    There is no exact ETA, for now, please, subscribe to this article updates by clicking "Follow".
    Manuel Kälin
    The application is only for 17.5 again?
    So it works correct in 17.8? Whats the problem here...?
    Ivan Postnikov (Edited )
    Hello @Manuel,
    There was a slight technical issue with "Applicable to" displaying.
    The bug is for both 17.5 and 17.8.
    The "Applicable to" is fixed and the issue should not reappear.
    Manuel Kälin
    "Applicable to" => again wrong???
    This KB is a bit useless if these informations are wrong...?!?
    Ivan Postnikov
    Hello @Manuel,
    "Application to" field behavior is not typical, the reason why version 17.8 is automatically deleted from this article is under investigation and should be fixed in a few working days.
    Sorry for the inconvenience.
    Manuel Kälin
    This Bug exists for 7 months now.
    When will this be fixed? We have some customers, who don't want to Upgrade from 17.5 to 17.8 till this is fixed!
    Kind Regards
    Ivan Postnikov
    Hello @Manuel,
    This will be checked in a scope of just created ticket.
