Warnings from Dovecot: Obsolete setting in /etc/dovecot/conf.d/11-plesk-security-ssl.conf
2 comments
    Atramhasis
    I use the latest version of Plesk (Version 18.0.21 Update #4) but still there are these warnings in the maillog. Are you sure it is fixed?
    1
    Leonid Gukhman
    @Atramhasis
    You can submit a support request to your hosting provider or Plesk directly to provide details that could help us investigate the issue.
