How to enable Serve static files directly by nginx by default?
3 comments
    Daria Gavrilova
    Hello @Mehmet,
    Thank you for your input!
    As for the update of web server settings for all domains:
    Usually Serve static files directly by nginx can be enabled for all domains with the following command:
    # plesk bin site -l | while read i; do plesk bin domain --update-web-server-settings $i -nginx-serve-static true; done
    More information on this matter you can also find in the following article: How to update web server settings for all domains via CLI
    As for the creation of Event Handlers via CLI:
    The article was modified accordingly.
    Mehmet Emin Aydın
    Update current host using this command
    mysql -Ns -uadmin -p`cat /etc/psa/.psa.shadow` -D psa -e 'select name from dns_zone ORDER BY name ASC' | awk '{print "plesk bin subscription --update-web-server-settings " $1 " -nginx-serve-static true -nginx-static-extensions \"ac3 avi bmp bz2 css cue dat doc docx dts eot exe flv gif gz htm html ico img iso jpeg jpg js mkv mp3 mp4 mpeg mpg ogg pdf png ppt pptx qt rar rm svg swf tar tgz ttf txt wav woff woff2 xls xlsx zip\" "  }' | sh
    Mehmet Emin Aydın
    You can use the following code to add event without logging in to Plesk panel
    plesk bin event_handler --create -command "bash /usr/local/psa/bin/trigger.sh" -priority 0 -user root -event domain_create
    plesk bin event_handler --create -command "bash /usr/local/psa/bin/trigger.sh" -priority 0 -user root -event subdomain_create
    whole command list
    cat << 'EOF' >> /usr/local/psa/bin/trigger.sh
    #!/bin/bash
    sleep 10
    date >> /tmp/log 2>&1
    echo $NEW_DOMAIN_NAME >> /tmp/log 2>&1
    plesk bin subscription --update-web-server-settings $NEW_DOMAIN_NAME -nginx-serve-static true -nginx-static-extensions "ac3 avi bmp bz2 css cue dat doc docx dts eot exe flv gif gz htm html ico img iso jpeg jpg js mkv mp3 mp4 mpeg mpg ogg pdf png ppt pptx qt rar rm svg swf tar tgz ttf txt wav woff woff2 xls xlsx zip" >> /tmp/log 2>&1
    EOF
