If you had already registered your account at MyPlesk.com/Plesk360/Platform360 please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Notification in Plesk: Error: ASL has not been configured run-parts: /etc/cron.hourly/asl exited with return code 1
21 comments
    Alexandr Redikultsev (Edited )
    Hello everybody!
    The article was updated with only Plesk UI solution that should work without any need to access the server via SSH.
    Do not hesitate to leave a comment in case it is not working.
    1
    Eef Vreeland
    Hi Alexandr,
    Hats off, I am glad to inform you that the suggested solution worked. Tomorrow I will check if the rule-update went well but I don't expect any problems.
    I think `apt-get install linux-generic` did the actual tric.
    Thank for teaching me `Search, and find it .... in front of you` ;-)
    Take care,
    Eef
    1
    Hello, @Eef Vreeland.
    I think the cause might be the same as described in the following article:
    https://support.plesk.com/hc/en-us/articles/360006023734-Cannot-activate-ModSecurity-aum-uses-100-CPU-on-Ubuntu-16
    I suggest updating the OS to the most recent version including installation of kernel updates to resolve it.
    1
    Nathan Walsh (Edited )
    We had this occur again today. 14 VMs. Had to manually run through each machine (as root user) with:
    # aum -c
    This seemed to do the trick.
    Hope this helps.
    1
    Hi, @Arnaud!
    Based on our information, fix should he delivered in scope of the rule set updates, in case the issue is still actual, force the Atomic Basic ModSecurity rule set update by switching it on and off via Tools & Settings > Web Application Firewall.
    Ivan Postnikov
    Hello @Martina,
    The error you show is Outlook-specific and is usually caused by Outlook misconfiguration.
    Make sure that you have selected the correct ports for mail protocols when were setting it up.
    In case the instruction does not help, contact Microsoft Support.
    Hello, @Globalhawk!
    I tested it a little bit more and was able to find another workaround: in case /etc/asl/config exists and empty, and there is no backup, navigate to Tools & Settings > Web Application Firewall > Settings, select any other rule set for a moment (for example OWASP ModSecurity), apply it, and then select Atomic Basic ModSecurity back and apply it.
    This actions re-created my /etc/asl/config.
    info
    After the command "run-parts /etc/cron.hourly/" nothing happens, it seems stuck.
    Robert (Edited )
    aum -c  gives -bash: aum: command not found
    yum remove aum
    downloaded aum-4.0.18-36.el7.art.x86_64.rpm package
    yum install aum-4.0.18-36.el7.art.x86_64.rpm
    now gives me new error
    Failed to install the ModSecurity rule set: modsecurity_ctl failed: HTTP Error 403: Forbidden Unable to download tortix rule set
    This Helped
    https://support.plesk.com/hc/en-us/articles/115000143534-ModSecurity-failed-to-update-rule-set-modsecurity-ctl-failed-HTTP-Error-403-Forbidden
    info
    That worked. After waiting about 10-15 minutes step 3 finished, and I could proceed to step 4. Thanks!
    Hi @info!
    It might be possible in case there were an interference with another task that was running from /etc/cron.hourly/. In general, in case there were no errors right after the start of run-parts, just interrupt the process.
    Hi again, @Victoria!
    Please, check the article once again and let me know if that helps.
    Arnaud
    I don't understand this page : it says the issue has been resolved on atomic side, if so why os it still hapening? (last alert 2 min ago)
    Globalhawk
    Problem is solved after manually recreating the config-file (touch /ets/asl/config) and switching back to Atomic.
    Lebb Leby Levbv
    It worked! :)
    Unknown User
    I recently change all the email setting to retrieve my email setting back but I am having an error 0x800ccc1a when I try to change its functionality. Firstly I want to solve my id issue then email.
    Hello, @Nathan Walsh!
    Thank you very much for the feedback!
    I have also updated the article with the resolution in case aum -c is not working fine.
    Globalhawk
    Same problem here (again). Neither, deactivating the Web Application Firewall NOR following all the steps until aum -c are working. I wasn't able to cp -a /etc/asl/config.rpmnew /etc/asl/config because that file does not exist. aum-c output is:
    root@login:/etc/asl# aum -c
    Errors were encountered:
    L CODE SOURCE                        MESSAGE
    4 9998 Core::_get_config             New key, updating config
    2 2    ASLConfig::config_update      An error occurred attempting to read file
                                         /etc/asl/config
    3 9998 Core::_get_config             Failed to update configuration
    4 9998 Core::app_exit                Exiting with error level 3
    VERSION info:
    First output was:
    root@login:/tmp# ls -lt /etc/asl/config*
    -rw------- 1 tortix root 1 Aug 31 06:32 /etc/asl/config
    Now same situation:
    root@login:/etc/asl# run-parts /etc/cron.hourly/
    run-parts: /etc/cron.hourly//asl exited with return code 1
    Can you make any suggestions?
    Hi @Victoria!
    Thanks for the report. We are checking this right now and will update the article accordingly.
    Eef Vreeland (Edited )
    Hi all,
    Every hour aum -u is started by cron. It immediately takes 100% cpu, never end (serveral days => never) and every hour another aum -u process starts.
    I tried a different ruleset, un- and re-installing, installing but not starting, from both Plesk and the command line, and read most of all contributions about the subject in several fora (problems began in 2014, went away for two years, re-entered in 2016, went away and now at 2018 they're back.
    I know that the error about 'There is no indication that the signature belongs to the owner' when updating ModSecurity is probably true but I use the basic ruleset.
    And apart from that, what is the reason behind starting some process, let that process delete files regardless if an update succeeds, consumes all CPU and waits til some admin has to kill (all) the process(es) and leaving the installation (and httpd/apache) un-intact?
    I'm on:
    OS     Ubuntu 14.04.5 LTS
    Product     Plesk Onyx
    Version 17.8.11 Update #27, last updated on Oct 25, 2018 05:09 PM
    The system is up-to-date. Checked on Oct 20, 2018 10:30 PM.
    In Plesk: Error: Failed to update the ModSecurity rule set. Details... (clicking on `Details` does nothing and stays away forever)
    In Advisor:
    ModSecurity is installed and switched on
    Fail2ban is installed and switched on
    The Advanced Atomicorp rule set is not selected
    Output of yesterday's top
    top - 20:03:46 up 4 days,  3:39,  1 user,  load average: 28.38, 28.69, 28.62
    Tasks: 374 total,  30 running, 343 sleeping,   0 stopped,   1 zombie
    %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    KiB Mem:  16406484 total,  7783124 used,  8623360 free,   698556 buffers
    KiB Swap:  7999480 total,        0 used,  7999480 free.  5345788 cached Mem
      PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
    29469 root      20   0   11048      4      0 R  29.9  0.0  19:23.19 aum
    16817 root      20   0   11048      4      0 R  29.5  0.0 207:55.42 aum
    21747 root      20   0   11048      4      0 R  29.5  0.0 133:35.61 aum
     4849 root      20   0   11048      4      0 R  29.2  0.0 477:09.53 aum
    13257 root      20   0   11048      4      0 R  29.2  0.0 289:10.83 aum
    14346 root      20   0   11048      4      0 R  29.2  0.0 260:43.22 aum
    26977 root      20   0   11048      4      0 R  29.2  0.0  52:12.38 aum
    28398 root      20   0   11048      4      0 R  29.2  0.0 651:53.11 aum
    29822 root      20   0   11048      4      0 R  29.2  0.0 577:14.79 aum
     1638 root      20   0   11048      4      0 R  28.9  0.0 875:06.00 aum
     5326 root      20   0   11048      4      0 R  28.9  0.0 695:15.47 aum
     5898 root      20   0   11048      4      0 R  28.9  0.0 432:27.56 aum
    18198 root      20   0   11048      4      0 R  28.9  0.0 183:07.16 aum
    28937 root      20   0   11048      4      0 R  28.9  0.0 994:38.02 aum
     6155 root      20   0   11048      4      0 R  28.5  0.0 522:27.41 aum
     7959 root      20   0   11048      4      0 R  28.5  0.0 357:21.69 aum
     9418 root      20   0   11048      4      0 R  28.5  0.0 324:11.07 aum
    27959 root      20   0   11048      4      0 R  28.5  0.0  37:42.10 aum
    28671 root      20   0   11048      4      0 R  28.5  0.0 636:26.94 aum
     7019 root      20   0   11048      4      0 R  28.2  0.0 393:33.48 aum
    15743 root      20   0   11048      4      0 R  28.2  0.0 231:46.61 aum
    24228 root      20   0   11048      4      0 R  28.2  0.0  94:25.83 aum
     4053 root      20   0   11048      4      0 R  27.9  0.0 757:24.98 aum
    19730 root      20   0   11048      4      0 R  27.9  0.0 158:11.23 aum
    25378 root      20   0   11048      4      0 R  27.9  0.0  74:13.44 aum
     2872 root      20   0   11048      4      0 R  27.5  0.0 818:15.13 aum
    23162 root      20   0   11048      4      0 R  27.5  0.0 115:04.31 aum
      541 root      20   0   11048      4      0 R  26.5  0.0 923:20.01 aum
    Both aum -u and aum -ck leads to `thermal-thrash-the-CPU`:
    output ps -ef | grep aum:
    UID        PID  PPID  C STIME TTY          TIME CMD
    root       541 32648 59 Oct25 ?        15:24:16 /var/asl/bin/aum -ck
    root      1638  1512 57 Oct25 ?        14:36:03 /var/asl/bin/aum -ck
    root      2872  2842 56 Oct25 ?        13:39:10 /var/asl/bin/aum -ck
    root      4053  4031 54 Oct25 ?        12:38:21 /var/asl/bin/aum -ck
    root      4849  4825 43 01:53 ?        07:58:06 /var/asl/bin/aum -ck
    root      5326  5260 52 Oct25 ?        11:36:05 /var/asl/bin/aum -ck
    root      5898  5800 42 02:55 ?        07:13:17 /var/asl/bin/aum -ck
    root      6155  6090 45 00:55 ?        08:43:22 /var/asl/bin/aum -ck
    root      7019  6935 40 03:56 ?        06:34:30 /var/asl/bin/aum -ck
    root      7959  7895 39 04:54 ?        05:58:11 /var/asl/bin/aum -ck
    root      9418  9168 38 05:53 ?        05:25:08 /var/asl/bin/aum -ck
    root     13257 13087 36 07:00 ?        04:50:07 /var/asl/bin/aum -ck
    root     14346 14253 35 07:56 ?        04:21:38 /var/asl/bin/aum -ck
    root     15743 15583 34 08:59 ?        03:52:36 /var/asl/bin/aum -ck
    root     16817 16778 34 09:53 ?        03:28:52 /var/asl/bin/aum -ck
    root     18198 18151 33 10:53 ?        03:03:57 /var/asl/bin/aum -ck
    root     19730 19585 32 11:55 ?        02:39:06 /var/asl/bin/aum -ck
    root     21747 21397 31 13:03 ?        02:14:32 /var/asl/bin/aum -ck
    root     23162 22947 31 13:54 ?        01:56:01 /var/asl/bin/aum -ck
    root     24228 24170 30 14:54 ?        01:35:22 /var/asl/bin/aum -ck
    root     25378 25267 29 15:55 ?        01:15:03 /var/asl/bin/aum -ck
    root     26977 26483 29 17:05 ?        00:53:07 /var/asl/bin/aum -ck
    root     27959 27919 28 17:53 ?        00:38:37 /var/asl/bin/aum -ck
    root     28398 28294 50 Oct25 ?        10:52:49 /var/asl/bin/aum -uf
    root     28671 28626 50 Oct25 ?        10:37:17 /var/asl/bin/aum -ck
    root     28937 28093 61 Oct25 ?        16:35:32 /var/asl/bin/aum -uf
    root     29469 29383 28 18:55 ?        00:20:20 /var/asl/bin/aum -ck
    root     29822 29764 47 Oct25 ?        09:38:11 /var/asl/bin/aum -ck
    root     31427 30456 24 20:03 ?        00:00:49 /var/asl/bin/aum -ck
    root     31531 31400  0 20:07 pts/0    00:00:00 grep --color=auto aum
    After killing all `aum` processes, CPU went from 100% to 0.5%
    Now details about the update itself:
    Error: Failed to update the ModSecurity rule set: modsecurity_ctl failed: gpg: key 4520AFA9: "Atomicorp (Atomicorp Official Signing Key) <support@atomicorp.com>" not changed
    gpg: Total number processed: 1
    gpg: unchanged: 1
    gpg: Signature made Wed Oct 24 23:26:39 2018 CEST using RSA key ID 4520AFA9
    gpg: Good signature from "Atomicorp (Atomicorp Official Signing Key) <support@atomicorp.com>"
    gpg: WARNING: This key is not certified with a trusted signature!
    gpg: There is no indication that the signature belongs to the owner.
    Primary key fingerprint: 1818 66DF 9DAC A40E 5B42 9B08 FFBD 5D0A 4520 AFA9
    TERM environment variable not set.
    --2018-10-25 16:56:19-- https://www.atomicorp.com/RPM-GPG-KEY.atomicorp.txt
    Resolving www.atomicorp.com (www.atomicorp.com)... 74.208.77.16
    Connecting to www.atomicorp.com (www.atomicorp.com)|74.208.77.16|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 1694 (1.7K) [text/plain]
    Saving to: 'STDOUT'
    0K . 100% 364M=0s
    2018-10-25 16:56:20 (364 MB/s) - written to stdout [1694/1694]
    aum failed with exitcode -15.
    stdout:
    stderr:
    Why keeps the aum-process running while it knows it didn't succeed?
    Switched to other rules (since updating fails)
    In Plesk, uncheck Atomic ruleset
    In Plesk, check OWASP (location: root@xxxxxxxx:/etc/apache2/modsecurity.d/rules/owasp_modsecurity_crs_3-plesk#)
    ...AND...
    killed (all) aum process(es) because every hour there's a new one.
    The config file is NOT empty
    -rw------- 1 tortix root 13357 Oct 27 14:43 /etc/asl/config
    -rw------- 1 tortix root 13097 Oct 16 00:59 /etc/asl/config.dpkg-dist
    Ehhhm, any suggestions?
    Kind regards,
    Eef
    Victoria R
    The error is now back. I followed the steps of enabling/disabling, it didn't fix it this time. Was there a recent update again?
