Plesk login is slow or impossible: a white page is shown instead.
Plesk interface and websites are working slow. For example, opening the menus Domains > example.com > File Manager or Plesk > Subscriptions takes significant time.
Restoration of a Plesk-made backup (specifically, the execution of the utility
/usr/lib64/plesk-9.0/sw-tar
) can take a lot of time. -
With the Plesk debug mode enabled, the commands logged to the log file
/var/log/plesk/panel.log
show that IO operations take a long time to complete:Example of a slow server:
CONFIG_TEXT: DEBUG [util_exec] [8053637617e48c1bb69e7a15225a3d18-0] Starting: filemng root file_exists /root/.autoinstaller/microupdates.xml --allow-root, stdin:
DEBUG [util_exec] [8053637617e48c1bb69e7a15225a3d18-0] Finished in 8.4113s, Error code: 0, stdout: 0
, stderr:
DEBUG [util_exec] [5b2bb52605a53] Starting: filemng root cat /root/.autoinstaller/microupdates.xml --allow-root, stdin:
DEBUG [util_exec] [5b2bb52605a53] Finished in 16.7445s, Error code: TRUE, stdout: , stderr:Example of normal environment:
CONFIG_TEXT: DEBUG [util_exec] [a05daf3428f1f60f55e3b94e5bfc4cb6-0] Starting: filemng root file_exists /root/.autoinstaller/microupdates.xml --allow-root, stdin:
[2018-06-21 21:23:54.472] DEBUG [util_exec] [a05daf3428f1f60f55e3b94e5bfc4cb6-0] Finished in 0.01272s, Error code: 0, stdout: 0
, stderr:
DEBUG [util_exec] [5b2bb4fa73614] Starting: filemng root cat /root/.autoinstaller/microupdates.xml --allow-root, stdin:
[2018-06-21 21:23:54.486] DEBUG [util_exec] [5b2bb4fa73614] Finished in 0.01314s, Error code: TRUE, stdout: , stderr: -
Disk write speed is very low:
Streaming I/O
# dd if=/dev/zero of=/root/testfile bs=512 count=5000 oflag=direct
3563+0 records in
3563+0 records out
1824256 bytes (1.8 MB) copied, 673.815 s, 2.7 kB/sExample of normal environment:
5000+0 records in
5000+0 records out
2560000 bytes (2.6 MB) copied, 0.0180294 s, 142 MB/s -
Latency
# dd if=/dev/zero of=/root/testfile bs=1024M count=1 oflag=direct
1+0 records in
1+0 records out
1073741824 bytes (1.1 GB) copied, 52.631 s, 20.4 MB/sExample of normal environment:
1+0 records in
1+0 records out
1073741824 bytes (1.1 GB) copied, 1.75607 s, 611 MB/s<
When running the utility
top
, high %wa percentage is displayed (CPU waiting for the IO resources):# top - 10:52:54 up 3:41, 7 users, load average: 105.98, 102.68, 107.96
Tasks: 466 total, 19 running, 446 sleeping, 1 stopped, 0 zombie
%Cpu(s): 8.5 us, 8.5 sy, 0.0 ni, 0.1 id, 82.8 wa, 0.0 hi, 0.1 si, 0.0 st -
iotop
, multiple processes are running with 99.99% IO:
The hard disk performance is unable to maintain the IO load.
Check the processes are run on the server and stop unneeded processes.
Contact the service provider to troubleshoot the IO performance and modify the disk subsystem to provide better IO.
Note: Amazon AWS and Lightsail instances may throttle the IO performance: I/O Credits and Burst Performance
4 comments
In my case, this basically happens when I try to open the overview page of a subscription (1 domain, 10 subdomains). It happens when using the classic, active, or dynamic list). sw-engine-fpm in these cases generates >99% IO according to iotop, while no other process generates any significant load.
Hello b_p
This behavior isn't typical.
Do you have a possibility to submit a support request for deeper investigation?
Ivan Postnikov not directly with Plesk (through a reseller only).
@b_p,
It's really hard to tell what is causing the performance issue without deep investigation.
So I'd strongly recommend you either submitting a request to the reseller (they will contact us in case of difficulties) or purchasing a support subscription to get support directly from Plesk Team.
