It is not possible to connect to a website over secure connection via cURL with the following error message:
# curl -v https://example.com
* About to connect() to example.com port 443 (#0)
* Trying 203.0.113.2... connected
* Connected to example.com (203.0.113.2) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* NSS error -12286
* Error in TLS handshake, trying SSLv3...
GET / HTTP/1.1
User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.13.6.0 zlib/1.2.3 libidn/1.18 libssh2/1.4.2
Host: example.com
Accept: */*
Connection died, retrying a fresh connect
Closing connection #0
Issue another request to this URL: 'https://example.com'
TLS disabled due to previous handshake failure
CApath: none
NSS error -12286
SSL connect error curl: (35) SSL connect error -
cURL package version is lower than curl-7.19.7-43.el6:
# rpm -qa | grep curl
curl-7.19.7-35.el6.x86_64
Outdated version of the cURL package.
Update the cURL package to the latest version:
# yum update
