How to enable a calendar for RoundCube on Plesk running server?
5 comments
    Gaël
    Hi.
    The link of the 1st answer ("Install the plugin Kolab/Calendar for Roundcube webmail") seems to be dead, and I don't find the page with the search tool on this support site.
    Should I understand that this solution is no longer supported and that I have to take the paid premium Kolab subscription ?
    Thx
    Anzhelika Khapaknysh
    Hi @Gaël!
    Thanks for noticing the invalid page.
    I've deleted the link as yes, the posted solution is no longer applicable.
    I recommend you either use Kolab webmail or a Horde one.
    Jorge
    Hi!
    How's the way to install modules in Roundcube if some one does not want to buy  Plesk Premium Email ?
    Following Roundcube documentation seems not to work.
    Thanks.
    Daria Gavrilova
    Hello @Jorge,
    Thank you for your question.
    Plesk does not officially support the installation of Roundcube plugins, so there are no manuals in regards of it from Plesk side.
    However you may try recommendations from our forum on this matter: How to add a plugin for Roundcube?
    In case if it does not help, please purchase Plesk Premium Email, powered by Kolab extension.
    Jorge
    Hi @Daria, thanks for your advise!
