- Plesk system updates failed with the following error:
PLESK_ERROR: 2018-06-22 11:42:40 INFO: pum is called with arguments: ['--update', '--json', '--unsafe', '--', 'kernel-firmware', 'kernelcare', 'mysql-connector-odbc', 'mysql57-community-release', 'procps']
2018-06-22 11:42:42 INFO: updating packages: procps mysql-connector-odbc kernelcare mysql57-community-release kernel-firmware
warning: rpmts_HdrFromFdno: Header V3 DSA/SHA1 Signature, key ID 5072e1f5: NOKEY
Importing GPG key 0x5072E1F5:
Userid : MySQL Release Engineering <mysql-build@oss.oracle.com>
Package: mysql57-community-release-el6-7.noarch (@/mysql57-community-release-el6-7.noarch)
warning: rpmts_HdrFromFdno: Header V4 DSA/SHA1 Signature, key ID cdef74bb: NOKEY
2018-06-22 11:42:57 ERROR: Public key for kernelcare-2.14-11.x86_64.rpm is not installed
2018-06-22 11:42:57 ERROR: Exited with returncode 1. -
According to the error the update failed on kernelcare-2.14-11.x86_64.rpm package:
PLESK_INFO: 2018-06-22 11:42:57 ERROR: Public key for kernelcare-2.14-11.x86_64.rpm is not installed
Note: the package is taken as the example. The package may differ
The absence of the public key from the corresponding repository.
Connect to the server via SSH;
- Check what repository provides the package:
# yum list kernelcare
Note: check the 3rd column to find out the repository
Check the repository in specified in /etc/yum.repos.d/kernelcare.repo file:
# cat /etc/yum.repos.d/kernelcare.repo | grep baseurl
baseurl=http://repo.cloudlinux.com/kernelcare/$releasever/$basearch -
Open the repository in browser and copy link to public key:
Import the public key:
# rpm --import http://repo.cloudlinux.com/kernelcare/RPM-GPG-KEY-KernelCare
Run the system update again.
OR
- Disable 3rd party repository by setting enabled=0 in
file.
